Garage Clean Out Phase One!!!!!
adrenalinepirate
Lakewood,CO
All out of a 96'. I am not on here that much, best way to get a hold of me is through email. [email protected] , can send pics through email.
This is a mid arm DIY kit from dirtbound. Y link setup for 2 inch lift to 8 inch lift. I will included 4 heims, tubing caps and a skid plate to make work for the t-case. I liked this setup due to not having the lower control arms attached to the cross member. $450
http://denver.craigslist.org/pts/4822693491.html
Grand Cherokee Hood vents. $40
http://denver.craigslist.org/pts/4822615995.html
Optilux H3 12V/55W Xenon Yellow Halogen Bulb Set
Brand New never used. $15
Brand new Shackle relocator brackets by Hd engineering. These are the no lift design. $80.
http://hdoffroadengineering.myshopi...oducts/no-lift-xj-shackle-relocation-brackets
Two stock height tires 225-75-15, great tread would make great rollers or spares. $20 each
http://denver.craigslist.org/pts/4793140341.html
Crossmember bolt on skid plate for Rough Country long arm kit. I was going to bolt it to a 2x4 crossmember I was going to build. It is new and has never been used or bolt up. $20
MSD coil pack for a hotter spark, used but works still. $10
4.0 alternator have two $20 each.
http://denver.craigslist.org/pts/4793100822.html
2wd half stubs for front axle $30 set or $20 each. My plan was to used them as a trail repair instead of carrying extra shafts.
2 sets of axle shafts, one set has tone rings $100
8 way Hella relay box new in bag. When I purchased it was $20 with shipping would take $10.
Aluminum replacement panels for side cargo windows. Brand New and never installed. Fits in stock rubber. $40.
Tailgate window clear with defrost. $20
Tinted side cargo windows $20 for the set.
Heater valves, have two but would take $20 for both.
aftermarket steering stabilizer have two. Low mileage thin body $20. 8k on it $10.
Bottle for defrost, blower and cruise control, stock location is on passenger side inside the front bumper. I relocated and reworked the tubing so with no front bumper you can bolt it under the brake slave cylinder and everything works correctly. If this makes sense it works great. $20.
Ignition with two sets of keys $20
steering column with ignition that has two sets of keys. $30
brake booster with master slave cylinder. $40
Radiator overflow bottle $20
Windshield wiper bottle, pumps work $20
Black short Radio antenna with base and cord to radio $5.
Climate control panel $10
Have a lot of items and will post as I go. Hope everyone's Christmas was a good one.
Dibs on the coil. Can I paypal you?
jeepdude25 said:
Ill take the ZJ Hood Vents. Would you be willing to ship them?? Ill pay for it
Thanks Ryan
Just trying to be helpful... :D
I have had the opportunity to visit with Corey a few times, at my house and his. Email is your best bet. :thumbup:
