M mudrat NAXJA Forum User Location scappoose Jun 27, 2011 #1 does anyone happen to have or know the fuse panel layout for a 94? i unhooked the unerhood light as it was staying on all the time and blew a fuse when unhooking now my radio is no worky. thanks...
1 1BrokeXJ NAXJA Forum User Location NE PA Jun 27, 2011 #2 Not sure if a 96 is the same as a 1994 but here is a fuse panel diagram for a 96 Passenger side kick panel fuse breakdown for a 1996 XJ 01 - 25A Rear Wiper/Washer 02 - 15A Radio, Cigar Lighter 03 - Empty 04 - 15A Passing Light 05 - 30A Blower Motor 06 - 30A (Circuit Breaker) Power Windows 07 - 02A ABS 08 - 20A Turn Signal Flasher 09 - 10A Radio/Clock Memory, Courtesy Lights, Glove Box, Cargo, Dome Lights, Telltales 10 - Empty 11 - 25A Headlamp Delay Module, Horn 12 - Empty 13 - 20A Power Door Locks 14 - Empty 15 - 15A Instrument Panel Lamps, Clock/Radio and Memory, Headlamp Switch, Parking Lamps 16 - 30A (Circuit Breaker) Power Seats, Trailer Tow 17 - 7.5A Instrument Cluster Gauges, Headlamp Delay Module, Chime Module, Overhead Console 18 - 25A Rear Defrost 19 - 05A Instrument Panel Lamps, Radio Illumination 20 - 5.5A (Circuit Breaker) Windshield Wipers and Washers
1 1BrokeXJ NAXJA Forum User Location NE PA Jun 27, 2011 #4 The above are the two I found, hope it helps you bud.
1 1BrokeXJ NAXJA Forum User Location NE PA Jun 27, 2011 #7 mudrat said: thank you Click to expand... Your welcome.
