Fujitsu P1510D Ultra Mobile Notebook/Tablet
JeepFreak21
Cameron Park, CA
I bought this ultra mobile convertable laptop/tablet computer new a little over a year ago. It's hardly been used and is in pristine condition! I had linux installed on this computer and never installed the touch screen, so it's only been used as a tablet a handful of times. The screen is like new and there are no dead pixels. I recently exchanged the battery because of a recall on the original one. The new battery has probably only been charged a half a dozen times. This computer works flawlessly. I restored Windows XP Tablet Edition 2005 and all the software that came loaded from the factory.
This computer comes with the factory restore disk and two software cds, the AC adapter, the standard capacity battery, a carry case, and the original stylus. There are no parts or peices missing from the laptop itself.
$950 OBO
(Pics and Specs Below)
Model
P1510D
Operating System
* Genuine Windows® XP Tablet PC Edition 2005
Software
* Adobe® Reader®
* Fujitsu Display Controls
* Fujitsu Driver Update Utility
* Fujitsu Hot Key Utility
* Fujitsu Touch screen Calibration Utility
* Microsoft Journal Viewer
* Microsoft Reader
* Softex OmniPass
Optional Software
* Depending on your system configuration, you may also receive:
o EverNoteTM Plus 1.0
o ritePen 2.5
o DialKeys by Fortune-Fountain
o Bluetooth™ Utility
Processor
* Intel® Pentium® M Processor Ultra Low Voltage 753 (1.20 GHz, 2MB L2 cache, 400 MHz FSB)
Chipset
* Intel® 915GMS
System Memory
* One Micro-DIMM slot
* 512 MB
* Maximum memory to 1 GB
Display
* LCD - 8.9" WSVGA display with touch screen
Video Controller
* Intel Graphics Media Accelerator 900
* Dynamic Video Memory Technology (DVMT) responds to application requirements and efficiently allocates the proper amount of system memory (up to 128 MB) for optimal graphics and system performance.
Maximum Resolution
* Internal display: 1024x600, 16M colours
* External monitor: 1600x1200, 16M colours
Hard Drive
* 30 GB
* 4200 rpm
* ATA 100
* Shock-mounted
Audio
* RealTek ALC203 AC'97 Rev. 2.3 compliant, 18-bit stereo full-duplex CODEC with independent and variable sampling rate
* Stereo and headphone/line-out jacks
* Microphone/line-in jack
* Internal built-in microphone included
Communication
* Multinational 56K4 V.90 modem
* 10/100 Ethernet LAN
Wireless Communication
* Atheros® Super AG® Wireless LAN (802.11a/b/g)
* Wi-Fi®, CCX, and WPA certified
* Diversity antenna
User Interfaces
* StickPoint by Alps
* 82-key keyboard with 16 mm key pitch, 2 mm key stroke
Ports
* Two USB 2.0
* External Monitor
* Modem (RJ-11)
* Ethernet (RJ-45)
* Headphone/line-out
* Docking connector
Card Slots
* One Type I or Type II CF Card slot
* One Secure Digital (SD) Card slot
Security Platform
* Integrated biometric fingerprint swipe sensor
* Embedded Trusted Platform Module (TPM)
* Security lock slot
Main Battery
* Lithium ion
* 3-cell, 10.8V, 2600 mAh
* Up to 3.5 hours of battery life
High-capacity Main Battery (Optional)
* Lithium ion
* 6-cell, 10.8V, 5200 mAh
* Up to 7.0 hours of battery life
AC Adapter
* Autosensing dual voltage support, 100-240V AC supplying 16V DC, 3.75A
Dimensions and Weight
* 236 mm x 167 mm x 35 mm/37 mm (9.3" x 6.57" x 1.36"/1.46")
* Approximately 1.0 kg (2.2 lbs.) (With Main Battery)
$950 OBO
