XJ-Mayhem
- San Jose, CA
Okay, story goes...90 xj 4.0 aw4... and about 2 months ago i was having a problem where i would randomly die on the freeway, but i just could throw it into neutral and start it right back up again and keep going. Happened about 2-3 times and every time I had my stereo playing rather loudly to compensate for road noise (after market head unit and front speakers, stock wiring) and just figured it had something to do with those few times i cranked it up real loud at my favorite part then died. So i stopped listening to music all together, and the problem stopped for the past month.
The other day, I drained the jeep completely of gas on my way home from school
and made my way to a gas station with my 1gal tank, filled her up, drove there and filled the tank and was good to go. It was a rough start after the 1gal red tank, and i had to flutter the throttle a little to get it to start but it roared to life.
Now two days after i ran out of fuel, and had driven about 45 miles on that new tank, i am on the free way and it does the shut off thing again (no music at all this time) and it feels exactly like it did when i ran out of fuel, sputtering but if i flutter throttle it runs rough. got it to the side of the road, managed to start it for a few seconds with a super rough idle and then it died. wouldnt start again.
now its home, and it cranks fine, but i don't hear the fuel pump prime like i normally do. I don't have a fuel pressure tester, but when i push in the little needle on the valve on the fuel rail, absolutely nothing comes out and very little to no resistance pushing the actual needle.
in my search here, i found a very useful post by Joe_Peters about this situation...but i do not know where to find the things like the "B Latch relay" to test with my multimeter, or really any of the other things he says to test.
I am going to start tomorrow by cleaning all the ground he mentioned, and see if that helps.
Pretty much it seems i have my diagnostic procedure already, but i just need it put into idiot terms so i can go through it tomorrow
Ok.
Renix, B Latch relay instead of ASD relay, essentially the same function. B Latch relay provides 12 volt power to the coil on the 3-wire connector at the ICM, pin "A", pin "B" is ground, pin "C" is tach. Check for pin "A" 12 volts and pin "B" ground. The B Latch relay also provides 12 volts to the fuel pump, bypassing the ballast resistor, when the key is turned to ON. After 3-seconds, when the ECU has received no signal from the crank sensor, the ECU cuts the ground to the B Latch relay and cuts off the fuel pump. Before we go any further, GROUNDS are CRITICAL to the Renix system. Three extremely important system grounds are at the DIPSTICK TUBE--the ICM, the ECU, and the o2 sensor. Clean down to bare metal, treat with anti-corrosive agent, make the connections TIGHT. Also, there is one and one only unibody ground--the POS braided strap from the head to the firewall. Replace with a 4 or 2 gauge cable, strip the surfaces to bare metal, anti-corrosive agent, and make the connections TIGHT. Now would be a good time to talk about the ICM to coil clips--they corrode overtime and need to be cleaned and treated with dielectric grease.
Ok. The 3-second prime is from the B latch relay bypassing the ballast resistor. Once the key is turned to START the 12 volts to the fuel pump is provided by the starter relay, again bypassing the ballast resistor. Once the engine starts, and is running at idle and all the way up to just short of WOT, the fuel pump relay sends 12 volts to the ballast resistor on the driver's side fenderwell--white ceramic piece, two wires--and then 6 volts runs to the fuel pump. You can jumper the two wires together eliminating the ballast resistor. The pump might be a little noisier. When the engine is running at WOT, 12 volts is sent to the fuel pump bypassing the ballast resistor, from the oxygen heater relay.
Cranks, won't start questions to be answered:
Is there spark?
Is there spark to ALL cylinders--is the rotor turning?
What is the spark's condition--blue and snappy (good), or yellow and weak (not good)?
Is the fuel pump running?
Is the fuel pressure correct?
Is there a firing impulse to the fuel injectors?
Do you have spark, and is it going to all cylinders? If yes, go to fuel. If not determine what needs repaired.
Is the fuel pump running? Yes, then test pressure. If pressure is good, then test for firing impulse.
Fuel, air, compression, spark, all in the right quantities, at the right time, in the right place.
Post back what you find.
