TerraWombat
- Eastern Shore MD
I can't seem to shake this problem - it started a couple of years ago when I noticed oil changes were getting increasingly thin and I was getting way more oil than I put in not to mention it smelled like gasoline. Parked the Jeep and it sat for a couple of years until I decided to figure out what exactly is wrong with it. Last month I sent the injectors out to be cleaned as someone told me they could be stuck open and allowing fuel to trickle past when the engine is off and it would seep past the rings and into the crankcase.
Unfortunately, that didn't seem to solve the problem as I drained all of the old gas today, put 5 gallons of fresh fuel in and ran the truck for a little while. Whether or not it's related, the truck idled a little rough, revved up pretty nice with no hesitation, but would backfire a bit coming back to idle. The truck is also running very rich as the electrodes on the spark plugs are very dark. My other suspect was the fuel pressure regulator thinking that the fuel is getting sucked past the diaphram and into the intake manifold, but I couldn't see any signs of that happening.
Anyone else have any ideas? I'm just about stumped at this point. The fuel system is so isolated from the rest of the engine that I can't fathom how I'm getting so much fuel into the crankcase. I literally changed the oil a couple months ago and have run the engine for maybe a total of an hour, if that, and the crankcase oil is already diluted to the point where it stinks of gasoline.
By the way, the truck is a 1988 Jeep Comanche SporTruck with a 4.0L engine and 5-speed manual transmission. There is 106k miles on the clock and the compression is 140-160 psi across the board. Seems a little high, but I suspect massive carbon buildup in the cylinders.
