tbburg
- Scottsdale AZ
I noticed the same hunting behavior while I still had the 3.55s. It'll still hunt occasionally on steep hills, but not often any more. (Most recently on the climb out of the valley on 17 north out of Phoenix)
techno1154: I did the 3.73s when I had to rebuild the rear axle, 'Figured what the hell, I had a above-split true-trac on the bench, so the front axle cost was a gear set and master rebuild kit. It actually worked out perfect(speedo is aprox. 2mph off, exactly the same as it was from the factory before I put the larger tires on.)
To everyone with the 30" tires/crappy mileage in 3rd: Can you tell if your torque converter is locking up? I was just wondering about that when I read MoFo's post. The way I shift(manually) is I wait for the trans to drop into 3rd, and accelerate back up to speed, then drop the shifter in 3rd when It's about 1-2mph below the cruise control set point. About 3 seconds later, I'll see about a 4-500RPM drop in engine speed when the TC locks in 3rd.(The TC won't lock in 3rd gear while the shifter is "D", but it should lock up anywhere above 19-2100RPM with the shifter in "3")
An unlocked TC may explain both the mileage and rpm differences we're noting. Also some of the heating up on long climbs.
By the way, I just went out up north last weekend. Spent 45 minutes, maybe as much as an hour in 3rd climbing out of the valley(1500 ft to 6900ft - GPS makes these numbers so easy to get!). For that 155 mile stretch, I got 18.2mpg.(included some of the downhill coming back, about 1000 feet of altitude. The rest of the trip down(about 4-4500 feet drop in 74 miles, I got an amazing 23 mpg! Total combined for the whole trip was 19.2)
