FS: scanner,block,cal cat,grill, flat top knuckles, 242 sye, stereo
chasdb
NAXJA Member 3643
Fullerton, Ca
Trying to finish my build need room in the garage to work and a few bucks! All parts in Fullerton, near 91 and Euclid.
Snap On Microscan, OBD2, abs, live data loaded w/OBD1 but needs optional cords, less than a yr old, took it on trips for peace of mind- only used a handful of times. Have all packaging never filled out warr card. $275 new was 399 for more info:
http://www1.snapon.com/diagnostics/us/MICROSCAN
00' 4.0L short block was in rollover. Has 1 broken engine mount bolt hole, slight dent in block where mount hit. Was siezed as water got in a few cylinders in storage, freed up with wd-40 so it will need to be bored. Dented oil pan. Crank and conectng rods should be good. Free
New Napa Cal catalytic converter #81515 for 96-97 4.0L 2.5" with used strap clamps. have box, receipt and warr card $140
XJ chrome grill $10
'76 K10 Chevy flat top disc brake knuckles, caliper brackets for going high steer on D44, Spicer # 636519, 636520 $150
Spicer outer shaft 9 5/16 19 spline $5 ea have 3
'97 up casette, cd OEM stereo $10
New Kenwood 5 1/4 speakers, needed 6 1/2" for my 2000XJ $25
Coleman thermo electric cooler 12V heats/cools $20
242 transfercase w/ Iron Rock Offroad SYE 23 spline input shaft. Presently still in jeep $175 comes with second '00 242 for spare parts, it's complete less rear seal and snap ring on rear output shaft/ also swapped input shaft w/ 242 currently in Jeep
2000 front bumper with recovery points and cut bumper ends to clear 33" tires $40
96-99 intake with fuel rail, injectors $40
alternator core 96 ish, wont turn- free..
89 starter no pic $5 works worn brushes
96 1/2 up disributor, good spare $10
I'm kinda digin the cooler.
... A poor Man's ARB.
Incoming PM.
Charles I'll take the OEM radio. Everything work OK on it? The CD player in mine is acting up.
How thick are the recovery points?
Incoming PM.
Ok, I'll call you tomorrow.
I thought I was having problems with driver's door speaker, replaced it and figuered out wiring had a break in the door jam. CD worked fine but I never tried the casette. Try it, if it works out for you pay me later.
Recovery point is 1/4" plate doubled up/ welded at the loop to the 1st pair of bumper bolts.
2nd on cooler if Russ isnt wanting it let me know
Ok, I'll let you know.
Interested in the bumper, has it been pulled from the points?
no, installed it for So Cal Fest but got a new bumper soon after.
Engine gone, thanks Gio for the beer
Cooler on it's way to Russ.
It dose have the pro software, enhanced codes, ABS, OBD1. The only vehicles I work on that are OBD1/2 are mine, everything at work is diesel Tier II/Tier III.
huh, thats an old thread. ;)
still have the knuckles?
Yes still got em, one stud is damaged for the steer arm and will need to be replaced. I was gonna keep them for spares but I will never break them at the mall.
I just got that cooler to Russ a few weeks ago:laugh:
