FS: Half Doors
ruggedjeep
Sherman Oaks
I picked these up from Johnny after his unfortunate roll on the con. I cut them stripped them, painted them and bought new hinges for them. The passenger side door will go on but the hinges need to be alighned a little better. The drivers side door hinges still need to be modified. The door handles have been cut but still function. I would like to keep them, but with the winter weather for the next 3 months, i just dont have room to store them. Pick up only, im located in woodland hills/calabassas. $75
here is the build thread if you care to see..
http://www.ruggedjeep.com/wforum/viewtopic.php?t=140
hey very interested!! so wats needed to fit the drivers side?! are they hard to switch back from stock to this?! thanks!!
The drivers side has the hinges on already and they are cut, the lower portion of the hinge needs to be hammered out. If you havent already gone doorless, check this write up that shows you how to do it step by step.
http://www.freewebs.com/mrmontez2000/DoorlessMod.htm
Once you do this, it takes 2 minutes to remove your doors and drop these in. They will be like a TJ door and just slide in and out.
i noticed the write up was for pre 97 hindges will it work with post 97?!
ok cool thanx, how far is woodland hills from temecula?! do u know?! thanks!
so the inside of the door is just bare
hmmmm not tooo bad im might jus have to come on up and take em off your hands! i'll find out a date i can make it up! if thats ok?!
Thats fine with me. Just let me know a couple days in advance.
So you know, these doors are not in great shape. They are trail doors that are unfinished. I would hate for you to come all the way here and decide you dont want them cus they're not what you expected. They have a few dings(after all they were involved in a rollover)
no thats fine! that what i expect for doors only being used for the trail an being involved in a rollover! only part im worried about is in stallin them...!
hah well i have a 2000 so i have the post...
ya i have the newer hinges....do u think maybe this weekend i could come down and get em'?!
