FS: AW4 core, Cobra CB, on board air, and other misc stuff
xjjeeper19
First up, late model 4x4 AW4. this is basically spare parts only. I bought it years ago as a spare for my jeep when I still had it. gear train is probably good, but not sure. I stole the Valve body out of it, along with the solenoid wiring harness. When I pulled the pan, it was fairly clean inside, no major metal chunks.
I will part it out, but I would prefer someone just takes the whole thing. bell housing is good, neutral safety switch is still attached along with both speed sensors. If you want just the output shaft, and the 4x4 extension housing to convert a 2wd to 4wd the price will be the same, because I will have to tear it down. I can get the converter if you want it, but condition is unknown on that a well
$50
Next up, Cobra model 29plx with a new cobra high gear mic, Wilson 38-39in silver load antenna, and the cable. Basically everything minus the mounting bracket for the antenna. this thing has way too many features that I will never need.
$100
Next is a few 12v Air compressors. I have a viair 350c in very great shape, And I have 2 of the smaller "airbag leveler" style both in good shape. one Is a firestone, and the other is air lift, both are basically the same compressor with the same specs.
$100 for the viair 350
$40 obo each OBO on the smaller ones.
Now on to the other random Items.
late model speed sensor housing with the 38 tooth speedo gear.
$20 ? OBO
Poweraid throttle body spacer for a 4.7L WJ, or Chrysler product with a 4.7L. Needs new gasket other wise I think its all there.
$20 ? OBO
Last is a new 8.25 3.73 ring and pinion with a few new bearings. I think they are carriers, but I will check.
$50
Not looking for any trades right now, I do take paypal and prefer not to ship anything.
Justin
Im in highland, just send me a pm and we can work it out. The trans is a 98-99 I think. It was a spare for my 2000
AW4 is sold! still have the rest, pending anthony on the speedo and downshift on the cb-ring and pinion
Found some more stuff...
Rubicon express flex joint tools, both the mall and large, and a summit machine joint tool as well. Not sure on the size, this is the old version before they had 4 different sizes. I can measure it for exact specs if needed. I would prefer to sell all them together, or at least just the two rubicon express ones.
$40 for all three
$25 for the RE one's
And a 48in Highlift jack. "used condition" probably needs a clean and lube.
$40
Justin
I've got two K40 5 foot antennas in good condition available. Both have the tunable tips for SWR adjusting. Just sayin'. :-D
Price drop on the compressors...
$80 for viair
$25 each for the small ones. $40 for both
Or
$110 for all three
