FS:: 96 XJ 8in lift 35bfgs $7,000 in New Jersey 08732
BMWSOB
New Jersey
1996 Cherokee-8 inches of lift. It is painted yellow, originally red. there are some chips here and there that you can see through. Engine blew the day i bought it, threw a rod. Installed a 98 cherokee engine with 50,000 miles on that i've owned for 3 years in my 89 cherokee. I origianlly purchased this engine with aproximatly 30,000 miles and maybe put 5,000 miles on it as it was a second vehicle. The miles aren't exact but they are low and the engine runs perfect. Full synthetic oil changes at least twice a year as i didn't put that many miles on it. Rustys 6 inch spring pack kit. Front has JKS Adjsutable coil over spacers. Rustys adjustable trac bar with mount. JKS quicker disconects. RE control arm relocation brackets. Stainless steel brakelines. Rustys solid tierod conversion kit. Rockcrawler brand black rims with 35 in BFG All-Terrains. RE hack and tap with cv shaft from a stock front shaft. 6 degree rear shims. Tereflex lift shackles to level the 8 inches out. Also recently put on some bushwacker cut out flares. Front and rear reciver hitches for tow points. 6 inch drop hitch for towing. It also has front and rear black outs for the headlights and taillights. Catch all front mats. rear cargo liner. The most important part- yellow smiley face painted on the diff. These pics don't show the wackers. they are on there now. i'll try to get some pics of them soon
More Pics upon request.
[email protected]
Bump for a good guy....I drove his last jeep with the same motor that is in this one....I just wish he had that body on it.
Stock axles and gearing right now. I was waiting to find the ideal axles for my set up. Haven't quite found what i was looking for yet. Its ready for an axle swap now though. I was using it mostly for going back and forth to work. I took it off road a little here and there, it was ok in high cruizin trails but anything else like in the pics i only used 4 low. In 4 low it performed awesome. I realize this isn't a great selling point but it is the reason its priced as it is.
