freaknzilla
- Texas
Zilla has been built for rock crawling, but does occasionally hit the pavement as well. It is also very stable at highway speeds. This rig is in excellent mechanical condition. All fluids are regularly checked, and have been changed as needed. Almost every mechanical modification or upgrade has been performed by or assisted with the help of Russ Baer of Baertrax, and has all been performed in the last 3 - 4 years. Russ knows this rig inside and out, and he can be contacted as a reference for any questions about it's condition and its trail capabilities. There are also many friends and fellow wheelers in several area off-road clubs including Texoma off-Road Club, LSJC, TexasJK, and TX4WD that can vouch for what this rig can crawl.
I have the receipts for the work and mods that have gone into this rig.
We have wheeled Clayton, OK., Hot Springs, AR., Katemcy Rocks, Trees Ranch, YO Ranch, De Leon, TX., Nocona, TX., Bridgeport, TX., BMRA, BVORR, and the San Juan's in southwestern Colorado.
The only non functioning part is there is no emergency brake. There are no other issues of concern on this rig, just the decision has been made to go in a different direction due to a lack of cash for another major re-build, and to pursue other interests..
modifications:
'94 YJ
88,000 miles
4.0 in line 6
5- speed
Ford 8.8 rear w/ disk brakes(Detroit locker)
spare set of 8.8 axle shafts
Blue Torch Fab 8.8 diff. cover
High Pinion D30 front w/ Yukon chromoly TJ shafts(Detroit locker)
Baertrax Buttface D30 diff cover(prototype)
4:88 gearing (Yukon)
Spicer 760 u-joints
RE Extreme Duty 4-1/2 “ suspension lift
RE shocks
2” body lift
U-bolts flipped up
motor mount lift
boomerang shackles front & rear
Banks headers & catback exhaust(complete front to back)
K & N cold air intake
Run Cool hood louvers
Grant steering wheel
Cobra CB & 4' antenna
AM/FM radio
hand throttle
Tuffy center console
Teralow 4:1 transfer case
Teraflex belly-up skid
Teraflex high knuckle steering
Teraflex drag link
Baertrax beefy tie-rod w/heim joints
Warn steering box skid
Warn gas tank skid
Nth Degree Mobility oil pan skid
SYE
Heavy duty front drive shaft(Drivetrain of Mesquite)
Line-X'ed inside(complete interior)
Poison Spyder trail cage, (floor bolted) ( Baertrax tubing modified- see pics)
Poison Spyder front trail stinger(Baertrax radiator hoop tubing-see pics)
Poison Spyder Crusher Corners(custom cut to wheel wells)
Poison Spyder tube fenders
Poison Spyder Rocker Knockers
Polyethylene off-road seats(stationary)
4- point harnesses(also have the crotch straps for 5-point but not mounted)
CJ drop down style custom made tailgate(diamond plate 3/16” steel armored)
4” round LED tail lights w/custom welded on light guards
Warn 9.5 winch(hand held & remote dash mounted switch)
custom built stubby rear bumper w/ recovery shackle mounts
Maxxis Creepy Crawlers-37” x 12.50 x 15”(4)
Irok Bias-ply (spare) 36” x 13.50 x 15”
Rock-a-thon black steelie bead locks (set of 4, w/ 1 Rockcrawler black steelie for spare)
night crawling lights
High-lift jack(tub mounted)
No A/C, but a great heater
No full soft top(but does have full soft doors)
removable Lexan Plexiglas windshield
Best Top safari top(gray)
Best Top Windjammer
Vertically Driven mesh bikini top
Best Top safari top (gray)
2010 OHV sticker
$7,000 OBO
Link to all the pics: http://s835.photobucket.com/albums/z...20sale%20pics/
$7,500
Contact owner:
Steve Sprayberry
Lewisville,Texas
[email protected]
214-662-6384
Reference:
Russ Baer@Baertrax
www.baertrax.com
972-406-9363
modifications:
'94 YJ
88,000 miles
4.0 in line 6
5- speed
Spicer 760 u-joints
RE shocks
2” body lift
U-bolts flipped up
motor mount lift
AM/FM radio
hand throttle
Teraflex drag link
Warn gas tank skid
SYE
Best Top Windjammer
2010 OHV sticker
$7,000 OBO
$7,500
Contact owner:
Steve Sprayberry
Lewisville,Texas
[email protected]
214-662-6384
Reference:
Russ Baer@Baertrax
www.baertrax.com
972-406-9363
