99xj4x4
- Bakersfield/ Chico
I am selling my JeepSpeed project because I need the money for school.
91 Jeep Cherokee, 4.5" lift, 33" tires, I6, all power, Automatic w/ an AW4 tranny, 200k on the clock, engine was built 50K ago bored (from 89.4 to 100mm), 8.25 rear end, solid axle I beam front.
Jeep is mechanically sound, runs really strong and is, and the engine was professionally built by a Jeep specialist shop with all OEM parts.
4.5" Rusty’s coils and shocks front
Custom leaves rear, 2" shackle, 1 ton over load spring, gas shocks on raised shock mounts.
Chrysler 8.25 rear axle
Clean AW4 tranny that was swapped in at the same time as the motor was built
Tranny Hi/Lo switch
New water pump and alt
1 ton steering
15x10 aluminum wheel
33" ProComp Ats
Magna Flow exhaust
Sony CD player, Mp3 and Sirius compatible
Balpunk rear speakers in a rear sound bar, Sony front
Custom light bar front
Front skid plate
Dana Spicer u-joints
Class 3 trailer hitch
Hood louvers
Custom Sway Bars
The bad:
It needs paint!
1 side has deep scratches from a tree branch
Needs some body work
2 teeth on the fly wheel are broken
The interior is in decent shape for its age but not great (I just had it steam cleaned)
The inside rear hatch panel is missing
The cruise control wouldnt work with the new throttle body
Heater/AC dont work great, probably just need to be gone through.
1 rear light is chipped at the bottom
Cracked windshield (if I dont get it replaced first)
Driver side mirror is messed up
The dash has some sun cracking
(im sure im forgetting some little detail)
If it does not sell I will be putting rock sliders on it, updating the front clip, and doing some minor body work, and painting it, in return I will be raising the price and re-listing it.
The Jeep is a sound daily driver, great off road, and it would make a great starting platform for some one wanting to build a JeepSpeed.
KBB put it at $2998 w/o the engine and some on the other upgrades the Jeep has. Im asking $3200 OBO
Tranny Hi/Lo switch
1 ton steering
33" ProComp Ats
Magna Flow exhaust
Front skid plate
Hood louvers
Custom Sway Bars
The bad:
It needs paint!
