FS 01 XJ Parts or whole
jdxj
Colorado Springs
Gonna sell my rig, part or whole not sure.
01 XJ needs some work, If someone wanted to put a lot of time and a little money with it it would be a decent trail rig, probley kinda past the DD days but i do drive it some. Honestly probley better to just use for parts to build another rig
has a good bit of rock rash.
needs a front bumper
Needs a new steering gear
Think the motor has bad head gasket( over heating issues)
hybrid cage not completeEXO is done just needs some finish welding on the inside and a few more braces.
home brew back bumper
Frnt D30 HP from a 99 XJ 4:56 lock rite locker
WJ Knuckles and custom built Hi steer Solid alum. diff cover
OTA trackbar mount and TB builder TB from TNT
$1500
Rear 8.25 with 4:56 and powertrax no slip locker
rough stuff cover
1 Spare shaft will work on either side
Shock mounts moved to top of axle for clearance and it allows stock length shocks
$500
Frame stiffeners from front of frame all the way to the rear spring mounts
TNT long arm kit with belly pan
$600
7.5 RE coils
$75
4.5 RE leaf packs
$150
1.5 Lift shackles
$75
All metal 3 row radiator
$100
FF dynamics triple threat electric fan setup
3 electric fans and cowls and temp switch
$200
AW4 tranny is good
$200
231 Tcase is good with RE hack and tap and front driveshaft conversion
$200
Mickey's MTZ's 35x12.5 on black rock crawlers 2 are about 50%
2 are about 20%
and I have a MT spare in good shape 60% but doesn't match
$400
Prefer to sell the whole rig but if it doesn't sell pretty quick i may part it out
but not gonna tear it down for the small stuff unless the big stuff sells first.
Will sell the whole rig for $4000
would consider trades for a stockish clean XJ
Located in Falcon area, East of CO springs
JD (719)313-0005
JD - Do you have any front shocks youre parting off of it? I'm in desparate need of a set.
Thanks,
Jim
Thanks,
Jim
You are totally not hitting craigs enough
I picked up a set of proper 10" travel bilsteins for the front of the 97 yesterday for $60
Up near you lol
Up near you lol
I just have literally no time to scour CL enough. The RS5000 shocks that I've got on their now are shaking the fillings out of my teeth and are about 6" too short on the droop.
7.5" lift
And the shocks I will sell if I part it!
They are just procomp 5000s
OK well let the part out begin, Cage is gone as well as fenders
Pretty much everything else is up for grabs, make me an offer.
I plan to rebuild this rig but its gonna be full with axles and probley a motor swap and total rebuild.
So prettymuch everything is going most of the interior, seats motor, tranny, tease, Driveshafts axles pretty much all of it
Gonna keep the long arms and belly pan but not sure about the springs yet probley sell for the right price. 4.5 RE leafs with 1.5 Tera flez shackles, 7.5 RE coils
Thing id be interested in trade for
9" rear housing
D 44 front
17 in beadlocks
atlas
LMK Make me a offer
Thanks JD
719-313-0005
Jim if you want the front shocks Their yours just come get em should have given them to ya the other day, least I can do for you helping me shuttle parts
Also have a home brew rear bumper and rocker replacements to sell $100 for the bumper and $75 for the rockers
Btw, I'll take $1000 for the front axle
And 300 for the rear
