JeepFreak21
- Cameron Park, CA
mad maXJ said:heims absolutely SHOULD be mounted with the bolt verticle for the end of a wishbone. they are much stronger that way.
now that's not to say that is couldn't work with the bolt mounted horizontal, especially if you use a 1" or bigger heim, but if you're building from scratch you might as well do it the right way the first time.
So, what if it's not a heim at the end of the wishbone? Beezil's first bushing was mounted with the bolt horizontal and I believe whatever it is he's using now is also mounted with the bolt horizontal.
[disclaimer]
I don't mean to keep using Beez as an example of the perfect setup, but his setup is the one I have pictures of for comparison... if I wanted to just copy his (or someone else's) junk, I wouldn't have opened this topic up for discussion.
[/disclaimer]
Billy
