Front LED Q's
Gooch1892
Detroit
So I replaced my running lamps and turn signals with some leds and now I have the usual assortment of issues. Headlamps work fine at all times, interior lights work fine as well, turn signals work fine, and all rear lights function properly. However, my running lights are acting up. They do not stay lit up when the headlights are on or when the switch is pulled to the one position, they only light up when I flip the turn signal lever, and they flash really fast. I searched around and came up with either needing a no-load flasher or adding a resistor in line with my leds...but nobody seemed to have the same problem that I am having, any help?
Thanks in advance.
