Front end noise when going slow and turning
Update: My noise was/is coming from the steering dampener where it mounts to the passenger side. The bolt was a bit loose but I think my dampener has worn out. It popped and moved a bit when the steering components moved. Had my XJ up on blocks doing a tire rotation and brake bleed... had my son get in and rotate the steering while laying on the ground. Found it pretty quick... thank goodness.
Something else to check and knock off the list.
