4x4nCherokee
- Pittsburg, KS
I lifted my '84 Cherokee awhile ago, but i never dropped the transfer case. I figured i'd hold out, and see how it did. Well my last wheelin trip, the front driveshaft started clicking real bad because of the increased angle. And i decided it was time to drop the T-case. I dropped it with no problem, but i got to looking at my CV joint coming off the transfer case, and it got torn up pretty badly. its an '84 so it has the true CV joint (coke can on a stick), not the double cardan. The rubber seal is all ripped up, and the metal edges are bent pretty badly. I've had a hard time finding these CV's b/c they were only offered for a few years, 84-88 i believe, and one that i was able to find at a salvage yard was in worse shape than mine. It would probably be alright if i could just get into it, and re-grease everything. But i dont know how to disassemble it. Also i have heard that the double cardan joints are better, so would it be better off just to switch to the DC joint, and if i did, what would that involve. I dont know if it would just bolt up, or if i would have to change out the slip yoke, or even the whole transfer case. Anyone else have similar issues, or have made the switch?
Thanks,
Matt
Thanks,
Matt
