front D44 info ASAP (SEARCHED!)
little red cheroke
Nashville TN
im writing a paper for school and need the following info ASAP
ring gear diamater (factory Jeep)
axle shaft spline count (factory Jeep) (after market up grades, if any)
factory gearing options and max gearing option (on any model 44)
u-joint size
and any other random info i might need for a compair and contrast essay on a HP D30 and HP D44 (the D44 axle in rubies is a HP right???)
THANKS
edit: i DID read the D44 tech article by CRASH but it was a wider range of D44s. im really looking for info on the HP44 used in rubicons.
If your english teacher is checking, its compare not compair.
