Front bumper finally on.
dphillips
See,what had happened was
Augusta GA
After procrastinating for a couple weeks, I finally got the JCR front bumper on.:yelclap:
All the holes lined up very well. The one I left open on the passenger side just needs drilled out. There is a hole there it is just partially covered by another peice of sheet metal. The coresponding whole on the inside of the rail is lined up with the tie in bracket. It was just getting too damn hot out to screw with it any more. I don't know what a V2 plate is.
I am running the exact same setup. There was a thread a while back about the tie-in plate holes not lining up. "Monkeyevil" on the board said they came out with new plates that line up perfect, V2 plates. Just curious of those were the plates.
Those are the V2.0 plates. The passenger side sometimes has a piece of sheet metal (on the inside of the frame rails) partially covering the two middle holes.
Dig the paint scheme BTW. Something different :cool:
Thanks.
:thumbup:
