front axle seal ?
jap813
I am needing to replace my front axle seals but am unsure what parts to order,
1989 xj
4.0
d30 NON disco
if I understand correctly there is only 1 seal on each side and they are the same?
any help is appreciated
:wave1:
How do you know when these need to be replaced?
I had a non disco D30 built and swapped in after stripping my R&P flat towing a couple years ago. I ran 2wd (no front shaft) for about a year, then last summer changed out the gear oil and put the front shaft back on for a Tahoe trip. I noticed some splatter on the inside driver wheel when we got there (approx. 500 miles). Level checked ok, wheeled it, drove home and level still checked ok and still does.
I don't want to damage my gears and locker, but also don't want to pull my front axle apart if i am just loosing a bit of gear oil.
