So, yesterday at 11am started on the oil pan change. at 230 i finally got the oil pan off. 4 layers (minimum) of seals: rubber, cork, cardboard (some sort of paper) and rtv holding it on.
put on the new rubber gasket, used rtv on the sides, and just a bit on the front and back to hold gasket in place.
at 800 i called it a day, screws were not lining up.
so this morning at 9 went back out there. finnaly got all the holes to line up, except 1. after a bit of work, got it all screwed down.
filled it with oil, put on a new filter, and started it up.
out the fricken back part of the pan, had an old faithful going on.
anyone know a shop in the springs who replaces oil pan seals? dont want to go through all that again.
