Ironmanandy
- North Carlolina
These are the fox bumps off our 5.9 race jeep. I no longer need them as I am doing a lower setup and need 2" travel bumps with a shorter overall height. They work fine and are in good shape. I can charge them to any desired pressure. They are currently at 200 psi.
I am also including a pair of the .250 wall DOM cans that allows you to put these inside a coil or butted between tubes for a structural joint with the bump inside.
The pinch bolt will need to be fabbed up by the builder.
Here are some pics:
This is an image of how they fit in place in front of a ZJ or XJ
Ill let these go for 280 shipped with the cans.
Call, txt, or email [email protected] 704 796 3502
Thanks
Andy
Here are some pics:
Thanks
Andy
