Ford F-150 Coils on Cherokee
GWS
I was just over checking out the jeepspeed site, and ran across an interesting post about using Ford F-150 coils as a cheap lift component for jeepspeed racing. Has anyone on this site used these? If so, how high a lift did you get?
GWS
Not gonna happen ...
You can use the Ford coils from an F-100 2WD , as they feature the last wrap that closes to around 2" diameter to fit around the stalk at the top of the XJ coils.
I believe the later model Ford F-150 with the TTB did the same thing...but I don't know.
Beware the spring rates on these things. The trucks weighed pretty close to 5 grand, and your XJ just weighs a little past 3 grand.
I am running coils from a 78 Ford F150 2WD on the front of my 89 and they work well. It actually rides smother than my 98 XJ with up country coils and flexes good.
The ones I got were used salvage yard units from a truck with a 302. They are a little small at the top but will work over the ring on the isolator after driving a while and seat fine.
I have no problems with them for the 20 bucks I paid.
Gained about 2.5-3" over stock height.
