- Port Orchard, WA
I have my 31 spline 9" stuff if anyone is interested:
What you get:
5.13 gears
Lock-Right locker
trussed housing
2 axle shafts
Drum brake setup
now for the bad -
the gears need to be set up in the 3rd member again. Gears are USED and have been run on a bad pattern, but should be fine strength wise, but will likely make noise...
the lock-right locker for the 9 uses the stock side gears, and one of them is broken (the side gear, not the locker pieces)
The housing is trussed on the bottom :confused1
One axle shaft is twisted, and another axle shaft is not twisted, but the backing plate that holds the shaft in is a 'custom fit'...
I have a broken shaft with a proper backing plate that can be had as well...
Consider this a rear axle in kit form with 'some assembly required'...
$250 for the gears and locker (loose and pulled from the 3rd)
$200 for just the 3rd member with the gears and locker
$150 for EVERYTHING (3rd, 2 'good' shafts, 1 broken shaft, drums, etc.)
Located in West Sac at Phil's house, can deliver to the toys for tots run in PRARIE CITY, will not ship.
What you get:
5.13 gears
Lock-Right locker
trussed housing
2 axle shafts
Drum brake setup
now for the bad -
