For the silver XJ lovers...
K5Matt
Bremen, Indiana
Paging Dan and Colin....
Found this at a nearby yard....
60th Anniversary edition.
If you need anything let me know.
Also found WJ leather seats. Fronts only, back seat was gone.
Jim Blount's, in Plymouth.
They have four xj's...two 96s, 98, and this 01.
They have a ton of ZJs/WJs too.
There is another yard in Plymouth too, Hunt's Auto Salvage. But their xj selection is picked over/hard hit wrecks.
Can you check the quality/price of the front fender please?
The flare has some scuffs on it, but otherwise it's in good shape. Want me to grab it for you?
Should have gone into more detail on these...
First 96 is white/gray, 2wd, auto. Hit in front.
Second 96 is red/gray, 4wd, auto. Hit in front.
The 98 is red/tan, 2 door, 4wd. Hit in front. Good glass. Interior is fairly complete.
The 01, as pictured.
If the front dome light still contains the RKE module I would be VERY interested in it and the rke remote on the keys in the ignition!
Was the leather wrap on the steering wheel in good shape and did it have cruise?
I will have to check on the dome light and rke module. No gurantee on the fob working. Steering wheel has alot of weather checking on it. It did have cruise.
Re: Re: For the silver XJ lovers...
Check the price. If it's ~$50 then pick it up and I will get ya some money, then worry about how it's going to get up here, maybe a McTruck.
Flare doesn't matter to me.
Thanks Matt
I could bring it to the crawl... we'll figure something out if you need it sooner.
Heads up on the cruse....
I wouldn't bother if you're meaning the 01 with the popped bags. From what I've been told when the air bag deploys it usually takes the clockspring with it. :dunno:
Unlikely I would have been pulling the wheel anyway, due to the weather-checking anyway. The RKE stuff should be easy to get though.
Steering wheel on either 96 decent? Don't need the airbag necessarily.
The red 96's interior was trashed. It had a lot of miles on it. So I'd bet the wheel was coming apart like they all do. The white one...I'll have to check.
I'm in need of a pass side rear flare in silver. Can you grab it if the paint is good on it?
I know that flare is in good shape, I'll get that for you.
