YELLAHEEP
- Littleton, Colorado
Nice, clean D300 t-case, flipped and set up for use in an XJ or MJ. Front input has been modified to mate up to AX15 or AW4 with 23 spline.
Worked excellent and the twin stick set up shifted easy and solid.
Have a trans mount custom made to work with this set up and a stock cross member.
It will need minor repair - one of the shift rod bushing covers got damaged and leaks. Should be an easy fix.
In order to install this, the AX15 output shaft needs 3/4" cut off the end. Not sure if the same goes for the AW4. To keep from having to do this, I'd recommend getting an adaptor ring which will also let you clock it to your desired position.
Asking $500 for the whole set up.
Will get pics up soon.......
