IH8RDS
- Hampton, VA
I just put on a set of Destination M/T's. I have had BFG M/T and Wrangler MT/R's. Fovoite tire was the MT/R. If you run in the snow allot the general consensus in BFG A/T
I have taken them into 18" snow with great results aired down to 15 PSI. They gripped great and got me around quite well. Ice sucks but then again unless you have studded tires ice sucks period.Slonopotam said:What about Firestone M/T on water, slush and ice ?
Living in Washington, I imagine, you should be getting a sufficient amount of it.
New rims are out of question this year, it turned out I owe IRS a bit more than expected :?. I will think about getting new rims together with new 33" tires AFTER I lift to 5.5" from my current 3.5.TiRod said:Since you are buying into a new set seriously consider 16" rims as part of the deal, if possible. BFG offers twice the tire sizes in 16", now, and you can keep a shorter sidewall height and lower the unsprung weight, which will help the handling.
There is a laboratory, called "cold region something..." they performed some test on snow traction, but i do not think any tests of rubber compounds. What I liked about them, is that they used Wagoneer quite some time ago for tests.TiRod said:I would like to see the results of testing to show which tire has ulitmate traction, and why - variation in tread, compound, aspect ratio, sidewall height, rim size and width, etc. Then we can see if an inch wider tire really has more than a few percentage points of traction, or some "facts" are proven to be counter-intuitive.
