rokk99
- Highlands Ranch, CO
I thought I'd share my experience of trying to fit 33x10.5's on a 2" BB.
The original build plan was this:
- Keep the 2" BB already on the Jeep
- Ditch the 30x9.50 BFG at's (which did not rub at all with no trimming) for some 33x10.50 KM2's
- New 15x8 wheels with 3.75 BS
- Re gear to 4.56 in the 30 and 8.25
- Add an ARB to the 8.25
Supposedly there are some people running this and love it, but here's what I found...
- The shop didn't have the KM2's, so they gave me Toyo MT's for the same price
. I really like these tires, they're aggressive and quiet on the road. The 4.56 gears are perfect for the 33's.
- I cut the fenders up to the washer bottle in the front and used the cut and fold in the rear. A 24 tpi jig saw blade worked great for this. I also used a Dremel with a cut of wheel for some of the tight spaces.
- We mounted up the tires and couldn't turn the wheel all the way to full lock. The tires hit at the back of the fender well. So, I broke out the Dremel and took off about an inch more at the rear. On level ground you can turn full stop now.
- However, there's only about an inch between the inner fender (yes I hammered the pinch seam flat) and the tire.
I can't see how this setup could ever really work unless you bump stopped so there was only a 1" gap between the upper and lower stop in front which would be really impractical for a street-driven rig.
Since funds are low now, I see three options:
- Get the Teraflex long arm with 4" springs, it's not much more than short arm kits with adjustable arms even though it's not a true long arm
- Sell the Toyos and get some 31's, but I DD this rig and think the 4.56 would suck on the highway with 31's. I know it was really bad with the 30's on the drive home from the shop!
- Try out some 32x11.50's, but I think this would still require more lift
Anyway, that's my experience for what it's worth. I don't see how the 2" and 33's can work without a stretch in front. I suspect either my suspension has sagged or others actually have more than the 2" lift advertised. Sorry there's no pics, I have them but it seems like you've gotta have them online somewhere before embedding them...
If anyone has advice feel free! Thanks
