1x:
http://www.jeepsareus.com/Merchant2...roduct_Code=Cfogwiring&Category_Code=CHEROKEE
1x:
http://www.jeepsareus.com/Merchant2...=JAU&Product_Code=MB12&Category_Code=CHEROKEE
1x:
Factory Fog light relay for '00 Cherokee (you can steal 1 from the wiring harness from the large section you will be removing).
To install:
1. Disconnect the battery
2. Plug in the Switch.
3. Pilfer the small relay from the wiring harness.
4. Install the 2 fog light relays.
5. Pilfer as much of the spade-terminated yellow wire (intended to go through the firewall) as possible.
6. Cut the yellow wire on the BIG relay to about 2".
7. Splice the long yellow wire to the wire you just cut.
8. Connect the wirning harness to the battery (through a fuse).
9. Run the wiring harness.
10. Open C106 (behind the headlight on the drivers side).
11. Remove the red plastic piece from the "inside" of the front lighting harness side.
12. Remove the proper grey plug from the back of the harness (see above pic).
13. Insert the yellow spade end (which now attaches to the large relay on the wiring harness).
14. Re-install the red plastic piece from the connector.
15. Re-attach the connector (c106).
16. Mount the lights.
17. Plug them in.
18. Go.
