F350 Crewcab Longbed 4x4
xjbump
F350 Crewcab Longbed 4x4. Its basically an 87' but was upgraded to a 97'. The nose was replaced with a 93 nose(seen better days) and a 95 bed. Truck has 60k orig. on it. 351 with C6 auto and I believe NP205. Truck has dual tanks, rear is leaking but new tank in box. It has new speakers in the doors and a JVC CD player. It has a new hitch as well as wiring.
Motor: 351W Bored 0.030 over, Edelbrock Carb, Intake, Cam & lifters, valvle covers, Keith Black, TRW, SVO, etc. for parts. Approx. 15k on rebuild. Hedman headers & Flowmaster muffler.
Axles are D60 front & 10.25 rear replaced last summer with 4.10 ratios and gone thru at the time. Hubs & bearings.
Steering links & tierods all replaced. New Skyjacker Steering stab.
Suspension has beefed up leafs, shackle reversal up front & airbags in the back. New Skyjacker shocks F & R.
35" BFG ATs with spare on steel wheels.
New radiator, heater core, starter, Alt., etc.
It has a steel lightning style cowl hood mounted on it and I have a Lund visor & Fastback for it as well. I also have a new nose to replace the one on it including: fenders inner & outer, front panel & brackets. I also have 2 new front doors that have power options that can be swapped in.
It has diamond plate siderails & a fiberglass cap w/tinted windows, both unmounted.I also picked up a new seat for it as well. I welded in new floor panels last summer as well. Tinted rear slider.
I have a few other parts I picked up like Int. wiper switch, hi beam switch, tach gauge cluster,newer washer pump and container, and more.
The only thing it needs is a front bumper, only wood one now, newer parts swapped on as you want and then paint.
I will even take payments from those I know. I'm basically looking to move this truck so its best offer right now until it needs to go at which time I may have to part it out.
$4000 B.O.
I'll post some pics below.
This pic shows it with weight on the rear and not sagging, the air bags only have 50lbs in them.
Plenty more pics upon request or come take a look. Dont be afraid to offer anything you want as long as your serious. PM me if you want. Thanks
