89 XJ. Runs great, 4.0L 4x4 automatic about 215K on original motor + tranny. Many new parts on this jeep, too many to list. This is my daily driver. ASKING $ 800 or best offer.
THIS JEEP NEEDS TO GO!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Take a look at the pics.
http://home1.nikonnet.com/servlet/c...SSWORD=nikoneditor_-614170821&WHO=memberguest
This is what I have done
Within the last 2 years:
oil pump,
water pump
thermostat
rear end bearing and seals
new breather air lines
distributor
upper and lower ball joints
U joints
front brake rotors, pads, and shoes
alternator
fuel filter
oil pressure sending unit
injector seals
crank shaft pulley
water pump or tension pulley
crank shaft positioning sensor
a couple of relays
map sensor
wheel bearing on the drivers side
I think that is it.
oil pump,
water pump
thermostat
distributor
U joints
alternator
fuel filter
injector seals
crank shaft pulley
a couple of relays
map sensor
I think that is it.
