stroked88
- Carlsbad NM
today ive been working on wiring up an extra set of reverse lights that will come on when i put the trans in reverse (5 speed), or with a switch. they are on a relay and i simply tapped into the reverse lights with 1 wire to activate the relay when the reverse lights come on, and there is another wire tied in with those that comes from the switch that turns on the factory reverse lights and the aftermarkets. My only problem is that when I turn on the lights with the switch with the trans in reverse while the key is off, I am getting feedback to my fuel pump, and am afraid i may not be able to turn the vehicle off if in reverse while switch is on. I found this link http://www.naxja.org/forum/showthread.php?t=1011302&highlight=extra+reverse+lights but need some help figuring out why it is feeding back and if someone has a good link for a diode that will work for my application. Ive googled and searched this forum and radioshack with no luck. All help appreciated. And sorry for the book of a post
