i'm putting my good control arms on probably this weekend when i have time to work on my jeep. and i have a simple question and no one in the tech forum gave me an answer. i have a set of extended uppers ( an 1" ) and i dont know how much longer my lowers need to be.
The uppers are two stock arms welded to boxed steel. The lowers are adjustable, I need to measure the uppers to find out forsure if there an inch longer.
But according to your math my lowers need to be 17 3/4th", I wonder if my lowers extend that much.
Ummmmmmm. What size lift are you gonna run. Moving the axle foward will let ALOT of things hit each other if you are not careful. For the axle to sit right with that size arm it needs to sit on about 9" of lift. Great for a mallcrawler not so great for anything else
Take the rustys uppers down to Oreilly's. There are replacement bushings out there. They may be two piece bushings but they will last a while and will get you back on the road. Just tell the OLD parts guy that you need bushings to fit the arms and then set it on the counter. You'll find something.
