2000XJSPORT
- Illinois
Hello,
With the help of JEEPZZ and many others. I have completed the install for the extended idle. It works great and it was not hard to install. As asked by JEEPZZ to reply on the activation light. I too could not get it to light up. I connected the ground, fused panel lamps dimmer switch signal, and the idle actuator, but did not connect fused ignition switch run. When I did connect the fused ignition switch run wire up to the correct color and number off the A/C plug. The switch did not work at all and the lights all dimmed in the car. So I cut it loose and left it unhooked. Also I did bypass C100 and C107 when running the wire from the switch to PCM C1 #12. If anyone knows how to get the light to work. I would really appreciate it.
Alex
Alex
