Extended Brake Lines for RRO 2" BB
96country
Russellville, AR
I will be installing a 2" RRO BB lift to my Cherokee this weekend. I was just wondering if I need to get extended brake lines? Other than this lift the rest of the suspension will be stock.
Thanks
Simply redrill the fronts and mount the brackets 2-3 inches lower, bending the lines straight a little. For the back, a 95 YJ rear brake line is about $30 and will give you 3 extra inches, which ought to be fine for you.
