krakhedd
- Buffalo, NY
2000 Classic, 4.6L stroker, Stage 3 Bulletproof (?) cam from 505 Performance, Stage 2 head from 505, 505 roller rockers, Clifford headers.
I want to run true duals, but instead of running them all the way back & over the rear axle (which I feel has too little clearance for an exhaust on the driver's side), I want to run 2" pipe through high flow cats & mufflers, and end them with downpipes. The downpipes would be located so they exhaust under the rear doors (I have a 4dr). Basically, pointing down & away from the vehicle at 40-50 degree angles on all three axes, just inside the frame rails. Also probably have an X-pipe.
Has anybody ever tried a setup like this on anything from bone stock to full-bore performance? What were your results?
Thanks guys
Thanks guys
