4WD.com has reman long blocks for 2500.00, That part# ATKVA31 and the specs with warranty are online as well as when you contact to order they will give you a list of shops in the area that can do the swap for you if you ask. will be more $$$$ to rebuild with machine work and parts and labor than to just replace. Unless you do all work yourself. Good luck sir
