XBoBJ
- Spencer MASS
i dirve five mins, 1 mile and the headers are glowing......
maybe try cleaning yours first with some carb cleaner
did you do the turn the key thing to get whatever codes were in there?
i'd say do the maf first, if you dont want to spend the money on a new one, get one used at sams just to see if thats it
but if it is the sensor, the mechanic is going to charge you labor AND $200 for the same sensor. besides, trail spares are always good
I'd get a manual and check the voltage going to the sensors first, then test the sensors. It won't take that long and it's free since you already have the multimeter.
all the shop is gonna do is plug in parts till they find whats wrong, mine as well eliminate the middle man...
glowing headers are a sign of running too lean. A large vacuum leak could cause this. the high rpm stumble is also consistent with this.
so my vote is running lean, from a large vacuum leak. Or a slipped timing chain.
ps. If that fuel pressure is staying low at high rpm, that could be causing a lean burn too.
