engine bog at 4000 rpm
mopwr2u
Portland,Oregon
Quick Question I have an 87 2.5L TBI and I get a fuel bog at 4000 rpm like it runs out of gas I have changed the filter and adjusted the pressure to 15 PSI
Never have been able to get above 4000 rpm since I got it in march. Could the pump deliver good pressure but not enough volume? Any suggestions where to start to cure this ? Could I run the pressure to like 20 or 25 without any damage?
ok
Ill try to bypass it before I cough up the money for a new one :shocked:
funny though at an idle seems to be alot of exhaust coming out the pipe seemingly unrestricted. but a full throttle may be diffrent.
Thanks
:firedevil I took off the cat and its an empty case nothing in it see straight through so I dont see any blockage there any other ideas? new injector maybe? Hopefully I can do some cheap trouble shooting first Im really limited on funds at the moment.
