4x4JeePmaNthINg
- Colorado
My cooling has never been better. I bypassed my radiator with the trans coolers and it's certainly helped the engine cool down quicker.
Dont fry your tranny! $$$$$$$
I saw an article of a 540 million dollar bust from Cat thieves, holy hellGet a new O2 sensor when you replace the cat, an old worn sensor can destroy a new cat
New 02s otw, trying for NGK but might have to use delphi unless ebay will have accurate parts/ not reboxed
If theft is an issue, only use the expensive cat on test days, use the cheapo cat minus the guts for the crooks to steal.
A friend of mine had his cat stolen, he replaced it, one month later it too was stolen. It is getting crazy. Time to hang cat thieves , and yes I am serious, death penalty for them, that will stop them.
I'm a little confused, are you under the impression my transmission is not being run through a cooler? To clarify My transmission is running into two small coolers, just not through the rad.Dont fry your tranny! $$$$$$$
Normally no it doesn't cook to bad, but on high alpine passes and some of the 12hr + driving I do, it coooooooks, toasty trans tunnel. I recently put on a second trans cooler and deleted the transmission input for now, just seeing how it goes for a bit. I did so because I didnt want to burn up the trans. 35s, low power on high alpine highway is not fun driving. I have read about the radiator helping the transmission get to temp, especially in the cold, however I haven't had any shifting issues. Is there more to worry about so far as that set up is concerned?X2. At least get a temp gauge in there so you know what it's doing. The trans shouldn't be adding a whole of heat under normal circumstances unless the torque converter isn't locking up. The heat exchanger in the radiator is meant to get it up to temp as well.
