Char-Broil
- PA
So I searched, but I'm lazy and of course everything that came up had to do with headlights. I don't see it as being much different though, so this may be a question I already know the answer to, just want to know if there is a better/easier or cleaner way to do this. I just got a Derale performance thermal controller for my taurus fan. Works great. It has a wire that the instructions say to run to ignition switched power, so the fan will only run when the key is on. It also as an override wire. Right now I have the ignition wire run to constant power and the fan runs for about 2 min after shutting the engine down on a mild day. Of course it kicks back on and off a few times as the coolant heats back up again. What I would like is for the fan to run the 2 min or so while the engine is still the most hot after shut-down, and then not be able to come back on. I figure a time-delay relay is the only/best way to do this, my question is, anyone done it and have a p/n of a good relay to use? How does the jeep headlight timer delay system work and can I re-purpose one of those for my fan? :dunno:
