joester1908
- Seattle, WA
I'm running a Rough Country long arm kit on my MJ. I went to adjust it this weekend and found this...
The flex joint on the upper control arm was shot. The metal disk was taco-ed, and the joint was completely unusable due to the threads being damaged. I went down to the local 4x4 shop where I bought it, and I was told that it was fairly common for those joints to blow out.
Rough Country doesn't sell just the joints, but they do sell rebuild kits, which were a week out. I decided I was going to upgrade
Here's the link to them if you're interested: http://www.currieent...ct.aspx?id=1262
The only issue with them is that the Rough Country ones have twice the thread. If yours are threaded out pretty far, these might not have enough. For me, they worked perfectly. They thread in and are the same exact size as the Rough Country ones. These are much more heavy duty.
I did not install lower johnny joints from Currie, I kept the RC ones because they weren't damaged. But these are the same size as the Rough Country lower joints. But the Rough Country ones had quite a bit more thread. I don't know if these would fit, but that is my guess if you're looking to upgrade: http://www.currieent...ct.aspx?id=2629
Here's the Currie Johnny Joints installed on my Jeep
I really like the RC long arm, but the joints kinda suck. Quick upgrade and waaay beefier!
