ktwalker01
- Jackson, WY
ehh.. nm
Priandhi Satria said:DR. DYNO
5-90
I'll go with the 68mm TB.
"enlarge the intake manifold plenum opening to match". Any suggestion on the intake, or the existing one should be fine ???
Thanks for the advise.
I'll post up the DYNO TEST Results...
Dr. Dyno said:Only an update on my own 4.6L stroker. I had my Jeep dyno'd earlier this month. The engine is a 0.020" overbored version of the 4.5L "poor man's" simple stroker on my site (stock cam, 9.2:1 CR, ported head with stock valves). The result was 205rwhp@4500rpm and 250rwtq@3500-4000rpm. The torque curve was as flat as Kansas with 88% of maximum torque produced at just 1500rpm. The only downside was that the rev limiter cuts in at only 4500rpm and I think the culprit is the JET Stage 2 chip.
Suwedan said:hi how are you?
I want open RPM more from 5200 to 6200 or more for jeep computer is year 91 to 95
what P\N the chip?
Suwedan said:how are you ?
I want P/N ?
BBeach said:If you guys read his last couple posts he's obviously some idiot just messing with you guys. He apparently wants a turbocharged 5.0 with jet chips, nitrous, 4.88 gears, 20" rims for racing.......:wstupid:
