Jelly Role
- Normal, IL
Thanks Phunk!
total toe .24+sarvermr said:please post your allignment specs. specifically your toe.
Yucca-Man said:..... only a plethora of contributing factors. "
PPpppbbbfffffffffffftttttt!!!!XJZ said:If you use the word plethora, you have to use other 4x4 mag words, like "venerable".
Such as "the venerable Jeep 4.0 should stop Death Wobble in it's tracks".
Tom Houston -
DW's are caused by a rather simple problem, but one that can be hard
to track down. Your suspension system (which includes the body) is
out of equilibrium. Energy is being temporarily stored somewhere and
then released, and the cycle repeated. Energy storage can be in many
different areas. It can be in the sidewalls of the tires flexing, or
the rubber in the bushings of the springs and control arms, or in the
springs, or even in the flex of the body. The energy being stored is
caused by something being loose in the system, such as ball joints,
tie rods, control arm bushings, leaf spring bushings, motor mounts,
etc. or something out of alignment.
What makes things tricky is that you can have all of these problems
and have no DW. It has to do with the rate at which the energy is
stored and released. If the storage and release rates are close to
the same, you are in for trouble. That is why changing tires many
times will kill DW. The new tires are stiffer or softer than the old
ones and as such store and release the energy at a different rate.
The purpose of a steering damper is to change the rate of storage and
release of the energy, just as are your shocks.
I say all of this to point out that you can have all of the equipment
working correctly and still have DW, but in most cases I have seen,
there is a defective component that you haven't found yet. My first
rule of thumb is to check all the rubber parts first. They fail the
quickest and store/release the most energy. Second is to look for
loose connections/connectors such as tie rod ends. Third is to get
out a tape measure and check that you have approx .125" of toe in
(difference in the distances between the front edge of the front of
the tires and the rear edge of the tires. After that I check the
castor. Lack of castor leads to a unstable system.
If all else fails, you need to retune the system. Start with a new
stabilizer if it is old or go to poly CA bushings.
Yucca-Man said:If all else fails, you need to retune the system. Start with a new stabilizer if it is old or go to poly CA bushings.
