I just had the same problem... I got a Renix flexplate when I swapped in an AW4 into my Sufa. Since I live in Israel and getting Cherokee parts is difficult and expensive, I built a little circuit that tricks the ECU to think it has the right flexplate. It works very well.
Here is the theory - the HO flexplate has three sets of four notches. The ecu sees three sets of four pulses from the CPS when the engine turns. The ECU syncs up on each set of four pulses, and figures out where the TDC is based on the fourth pulse in each set.
The Renix flexplate produces three sets of 20 pulses, 19 of which are shorted and 1 is longer (at least 6 times longer). The ECU syncs up on this pattern and figures out the TDC.
The circuit I built contans a small FPGA. It received the pulses from the CPS that senses a renix flexplate and syncs up on the 60 pulses. It differentiate between the large pulses and the short pulses, and figures out where the TDC is. Then, it generates a synchronized signal to the ECU with three sets of four pulses and the correct timing. The ECU receives this signal, "thinking" it comes right from a CPS that sniffs the right flexplate, and generates the correct timing (injection and ignition).
I'd be happy to share that design if anyone interested. The total cost of parts is about $30, but it does require some knowledge in electronics and programmable devices (FPGA).
Oded
