Vanimal
- escondido, ca
got some left over parts from my heep project.
here's the list, make offers
mj gas tank, no pump, one slight dent. $20
hp dana 30, disconnect. 3.07 gears, open, stock shafts. no brakes or unit bearings. $75
stock front driveshaft $40
stock rear driveshaft for a d35/manual trans. needs u joint at axle end, cap fell off. $25
pro comp drop lower control arms. worked great for my 3" lift, might work for more. bushings good, no death wobble. $50
stock upper control arms. a couple beers
aftermarket track bar, not sure of the brand but looks similar to my RE. needs bushing on axle end (poly). might have some, i'll check later. heim is good. single shear unless you get a double shear bracket. no hardware included. $40
1.5" lift shackles, greasable, in good shape. used for a few months, paid $85 for them, $50
brand new king 2.5IDx16" 300lb coilover springs. used for setup, but never driven on. $100/pr.
