driveline angle
moneypitxj
NAXJA Member #565
york, pa
what kind of degrees can we run a driveshaft at? and is there a better fix than just using shims? i dont know if it makes a differance but, i have an 8.25 axle along w/ the sye on a 241or.
When I swapped in my Full width 44, I mounted the new spring perches on an angle so the pinion has a slight upward angle...No more vibes. :guitar:
i do not have any vibration i was just wondering at what degree the drive sahft can befor the pinion could start to wear bad
The pinion doesnt even know/care about angles!Its only the u-joints themselves that have an operating lifespan based on the the angle it sees!They also have a maximum operating angle along with your yoke.
