Drive line angles
Pnwxj808
Port orchard WA
So I just lifted my xj with a rubicon express 4.5 lift and now I’ve got some good drive line vibrations. I know an SYE is recommended but I can’t afford it right now. So I’m thinking of doing a T case drop but I also know I need to shim the rear end and I’m trying to get some help on figuring out the right degree shims to put on with a t case drop any advise would help!! Thanks
I did the t case drop and it got allot better almost no vibration but came to the realization that I might need a slightly longer drive shaft to get the slip yoke back into the t case but slowly figuring it all out. Thanks for the advise!
