cherokeedriver420
- Sumner,Washington
I did mine about an 1 1/2"-2" apart much easier to fold them up looks pretty damn good.
Hudson Bend said:Using a dremel? I'd allow one week, seven new dremels and a couple gross of those cute little cut off wheels. Get serious. Get a grinder.
SoreRunner said:I used my dremel on two xj's this past weekend. I used almost 100 disc's on nw-xj-scott's Cherokee. Then I used about 50 on my Cherokee. Both took about 6-8 hours.
SoreRunner said:Something like those, those in particular are expensive. At Fred Meyer they are sold seperately. I bought 2 containers of the part number #420, and then the big kit of all cut off wheels for 23.00's. Very easy, just time consuming changing the damn disc every minute. The reinforced ones are the best, last a long time.
winkosmosis said:you don't have to go out and spend money on a tool you'll only use once just because some yahoos on a forum think a job has to be done in 2 minutes, even if it ends up sloppy.
Remember Bubba that there's always more than one way to skin a cat. Just because someone thinks their way is better doesn't make them a yahoo. When you make statements like that, then it's kind of like the pot calling the kettle black.
Jason's method is pretty easy though. As for a hacksaw...... thanks but no thanks.
MT Mike said:winkosmosis said:you don't have to go out and spend money on a tool you'll only use once just because some yahoos on a forum think a job has to be done in 2 minutes, even if it ends up sloppy.
At the beginning of the thread everyone was acting like a Dremel makes no sense, and then after he already went and bought a grinder, the posts came in about it being neater and not taking too long. If someone has never used a Dremel on metal, why would they assume that a grinder or sawzall is necessary and tell the OP to go out and buy one?Remember Bubba that there's always more than one way to skin a cat. Just because someone thinks their way is better doesn't make them a yahoo. When you make statements like that, then it's kind of like the pot calling the kettle black.
winkosmosis said:At the beginning of the thread everyone was acting like a Dremel makes no sense, and then after he already went and bought a grinder, the posts came in about it being neater and not taking too long. If someone has never used a Dremel on metal, why would they assume that a grinder or sawzall is necessary and tell the OP to go out and buy one?
winkosmosis said:Actually... instead of discs, what about the spiral saw? I have one for my Dremel that I've used for wood and it worked great. There were two in the pack, the other was designed for metal. I assume it would be hard to control unless you use a template, but for cut/fold it should be fine
no for eithere, but i assume you're talking about the rear... i was just using a hammer and didn't fix the flaking paint yet when i took the picture... you know... i still haven't fixed it :guitar: it looks fine from farther away than 6"SoreRunner said:Sorry, not towards you in any way, but that looks terrible in any which direction you look at it.
Were you :gee:, when you did this?
asp387 said:if you're talking about the front... :moon: too bad i think it looks fine haha. it's a jeep, not a ricer.
