Sidewinder CC
- Canton, Michigan
If you can view a graph of the O2s on a scan tool output, you would see the upstream with a spiked pattern; Very quick and extreme switching from lean to rich (0v to.9v) as the ECM adjusts fuel injector pulsewidth. Looking at the downstream you should see even, smooth swings that look fairly flat. Usually some where between .3v to .6v. If the down stream waveform becomes steeper and spiked like that of the upstream, the CAT is loosing it's ability to clean the exhaust.
The downstream 02 is used to "fine tune" fuel mixture to keep the CAT inside this target window of .3v to .6v If the ECM sees the D/S voltage trending too high, i.e. staying more towards .6v, it will lean the mixture to set the trend more neutral, and vice-verse.
The ECM will set a CEL for cat efficiency when the average stays too high, and it cannot compensate by adjusting mixture, or the waveform becomes too spiked and starts reacting quickly to fuel mixture changes.
All that being said, a downstream O2 will not, typically, affect driveability in the least, including fuel efficiency.
If you addressing me here. I understand all that.
My scanner is a simple scanner, without graphing.
